46 Users Online (44 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Where is the 2010 Patterns Folder?
Mon, Apr 26, 2010 at 5:42:57 PM | Where is the 2010 Patterns Folder?
PatrickReynolds
PatrickReynolds Avatar
I am attempting to create a detail component of steel decking that already has concrete built in on top; unfortunately concrete is not a default option for the fill patterns for regions so I'm having to create a new one and define it manually.  The problem is that I cannot find the folder with all of the revit 2010 pattern (.pat) files.
Could somebody -please- direct me to this folder.  Thank you.
Tue, Apr 27, 2010 at 7:23:51 AM | Where is the 2010 Patterns Folder?
It is not in the library area.   Look in your program installed location in the Data folder.
Tue, Apr 27, 2010 at 9:01:08 AM | Where is the 2010 Patterns Folder?
PatrickReynolds
It doesn't seem to be there either.  I know it's here somewhere '-_-
Tue, Apr 27, 2010 at 9:18:29 AM | Where is the 2010 Patterns Folder?
4 Stars: 203 Votes
Directly from the HELP menu...
Tue, Apr 27, 2010 at 9:21:44 AM | Where is the 2010 Patterns Folder?
Mine is in C:\Program Files\Autodesk Revit Architecture 2010\Data\Revit.pat
All the pattern files are in that one file.
Tue, Apr 27, 2010 at 9:41:35 AM | Where is the 2010 Patterns Folder?
4 Stars: 203 Votes
And mine is in d:\Program Files\Autodesk Revit Architecture 2010\Data\Revit Metric.pat
Tue, Apr 27, 2010 at 11:17:16 AM | Where is the 2010 Patterns Folder?
PatrickReynolds
Ah, I was hunting for an individual concrete.pat file.  '-_-
Well, once again, thank you for the help.
Tue, Apr 27, 2010 at 11:27:12 AM | Where is the 2010 Patterns Folder?
4 Stars: 203 Votes
check this: http://www.revitcity.com/forums.php?action=viewthread&thread_id=1284
If you search for "Patterns" you gonna see lots of threads about this....
Tue, Apr 27, 2010 at 11:44:11 AM | Where is the 2010 Patterns Folder?
PatrickReynolds
The revit.pat had what I was looking for, but thanks for the link.  It'll be good to know once I start making my own patterns.
Much obliged.
Tue, Apr 27, 2010 at 12:21:07 PM | Where is the 2010 Patterns Folder?
We would have gotten here a whole lot quicker if you had said you were looking for one file.  The conc.pat is part of the complete pat file.  It can be loaded at different scales if you want to do that.  It can also be isolated to it's own file - just delete everything else and save the file as conc.pat.
Is there a way to preview .pat files / hatch patterns in thumbnails in a folder?
Mon, Jul 6, 2015 at 11:01:27 AM
Importing multiple fill patterns
Fri, Jun 22, 2007 at 11:50:51 AM
Editing Model Patterns...
Mon, Jan 4, 2010 at 12:56:51 PM
Opening a 2010 file in 2009
Thu, Jul 16, 2009 at 8:51:57 AM
Browser Sub Folder
Tue, Sep 15, 2009 at 6:59:30 AM
Page generation time: 0.4115
