65 Users Online (62 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Sheet Parameters
Mon, Apr 26, 2010 at 2:13:43 PM | Sheet Parameters
col9000
Hi,
I'm having serious trouble getting my head around the way the various parameters work in titleblocks. I understand shared parameters in general, but I can't figure out how to make titleblock parameters editable in a project in this situation:
If I place a lable on a sheet template family file, a window opens allowing me to pick a parameter. Say for example I pick "revision letter" from the standard list. How do I get this parameter to relate to my shared parameters file so that I can load it into a project? I can see that, if I make a new parameter in the shared parameters file called "revision letter" I can load it into both the sheet and the project... but in that case what is the point of the list of standard category parameters that you can choose from?
If anyone knows of a good tutorial on this I'd appreciate it.
Thanks!
C
How to make sheet parameters RELATED
Thu, Nov 26, 2015 at 5:48:31 AM
Delete "stock" Project Info. & Drawing Sheet Parameters?
Mon, Nov 23, 2009 at 4:05:41 PM
sheet index (list) not organizing properly
Thu, Sep 15, 2016 at 4:13:56 PM
Sheet List Parameters
Thu, May 1, 2014 at 2:22:05 PM
Placing Parameters on Cover Sheet
Fri, Mar 19, 2010 at 5:33:07 PM
Page generation time: 2.8007
