60 Users Online (59 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Modifying Default Family Templates
Mon, Apr 26, 2010 at 10:58:53 AM | Modifying Default Family Templates
johnnyutah54
In a nutshell, I am trying to figure out if it is possible to either a) modify the existing family templates that come with Revit, or b) save our own family templates to be used later?
We have custom shared parameters on our door families to make the doors schedule the way that we want. This works very well for modifying existing door families, however, when someone tries to create a new door with the door template those parameters must be added in manually. I would like to add our parameters to the door template so we can avoid that issue.
From what I have seen, I can't find any way to do that. Am I on track on there or am I missing something?
Thanks!
Mon, Apr 26, 2010 at 12:00:10 PM | Modifying Default Family Templates
No way to save the template I believe.... Just create a new door with only your parameters in it and save it named as a door "template" but as a family and in the template location.  You might want to rename the door template to See>>> xxx family.  Now to create a door, they have to start with the family instead of a template.
Mon, Apr 26, 2010 at 2:20:23 PM | Modifying Default Family Templates
TKennedy
4 Stars: 7 Votes
Actually, if you set up your new template family like WWHub said, you can then cnage the file extension from .rfa to .rft, and it works as a new family template.
Edit:
I should say, it works as far as I can tell.
Edited on: Mon, Apr 26, 2010 at 2:20:57 PM
Any problems with modifying installation file locations?
Tue, Mar 10, 2009 at 10:04:18 PM
Default templates and families missing from Revit 2016
Sat, Jul 15, 2017 at 10:14:48 AM
Default Level of Template
Mon, May 10, 2021 at 2:50:03 PM
Family parameter-SOS
Thu, Dec 1, 2005 at 6:23:38 AM
Used based Revit templates
Fri, May 2, 2014 at 5:17:38 AM
Page generation time: 2.8634
