50 Users Online (49 Members):
Forums >> Revit Building >> Technical Support >> Revit 2010 64bit Save times
3 Posts No Rating |
Hi, We have two users currently using Revit 2010. They are not using central files. The file sizes are roughly 20meg and are now taking nearly 2mins to save (locally or to the network). If they use the same file at home I have been told the save time is almost instant. Any ideas as to why this is taking so long? Machine Specs: Microsoft(R) Windows 7 Professional Intel Core2 Quad Q9400 @ 2.66GHz 8Gb RAM Quadro FX 580 PCI-e Graphics Card Thanks Dan Edited on: Mon, Apr 26, 2010 at 7:59:38 AM
Edited on: Mon, Apr 26, 2010 at 7:59:51 AM
2 Posts No Rating |
Are they following all of the "good practices" when saving? For example, closing all the hidden windows before saving?
I would verify that when syncing to central you are not always relinquishing worksets, compacting the file and saving locally before and after. These are all options found in the "syncronize with central" dialogue. If that doesnt speed things up my guess would be you have a bottleneck somewhere on your network.
3 Posts No Rating |
Hi, Thanks for your reply's. They are following the best practices yes and they are not using shred files therefore i believe they are not saving to central (please correct me if im wrong, im a computer engineer who has no clue when it comes to CAD) If there were a bottleneck somewhere on our network would the save times not be considerably faster when saving to their local machine? (which as stated is unfortunately not) Thanks Dan
Something wrong in your setup or system. Save times for both stand alone or shared files would be almost nothing for a file this size. And we are on 32 bit systems.
3 Posts No Rating |
I guessed it wasnt right, any ideas of what could be wrong?
Revit 2010 Crashes when trying to save and or open files. |
Thu, Jul 2, 2009 at 1:51:09 PM
Problem with Revit 2010 save file format? |
Wed, Aug 12, 2009 at 9:24:58 PM
Revit 64bit & RAM |
Tue, May 4, 2010 at 9:02:19 AM
Revit Libraries fro 2010 to 2011 |
Wed, Mar 2, 2011 at 3:09:49 PM
2010 is slow |
Tue, Sep 22, 2009 at 1:53:07 PM
Members: | 2017300 | Objects: | 22947 | Forum Posts: | 152212 | Job Listings: | 3 |
