86 Users Online (85 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Problem with windows in corner
Mon, Apr 26, 2010 at 2:44:14 AM | Problem with windows in corner
bengtm
3 Stars: 2 Votes
Hey, I'm having a problem that I don't really know how to solve.
 Please watch the attached picture!
 The problem is that when I attach two windows to the corner (or one window at the upper wall) you can see that the wall just goes straight out into nowhere instead of "closing in" Compare how the wall in the corner behaves in the left and right pictures compared to the middle one.
 The weird thing is that on the middle picture I've attached the window to the corner on the vertical wall, and there's no problem, but if I do the same thing on the horisontal wall, the vertical wall will just go out into nowhere.
 It's a problem that can be solved by moving the window 1 millimeter away from the corner, but I don't see that as a legitimate fix.
 Anyone else experienced this and know about a fix?
Kindest regards.
Mon, Apr 26, 2010 at 7:19:14 AM | Problem with windows in corner
Try this sequence - may not need #1
  1. Set location line to exterior
  2. pull one window back from the corner
  3. edit the wall join using the miter setting
  4. Put the window back
Mon, Apr 26, 2010 at 7:53:50 AM | Problem with windows in corner
bengtm
3 Stars: 2 Votes
Solution worked perfectly, thank you very much!
Corner windows with variable angle
Tue, Dec 27, 2016 at 4:47:10 PM
corner windows
Tue, Jun 3, 2008 at 10:56:06 AM
Corner windows
Thu, Apr 10, 2008 at 9:14:45 AM
Corner Windows
Fri, Sep 11, 2015 at 11:03:10 AM
Commercial Aluminium windows
Mon, Oct 31, 2005 at 7:57:32 AM
Page generation time: 0.9495
