Forums >> Revit Building >> Technical Support >> Perforated Metal Panels
10 Posts No Rating |
I was wondering what is the easiest way to create a drop ceiling with perforated metal panels (so light can go through), without having to make each one individually.
You don't need to make each one individually, use the "MATERIALS", like you can see by the images use Metal material then you can chose the "Cut-outs/Perforations" or you have already, in the Metals, some of them like you want... take a look
The material you showed looks like what I want but I was thinking 4x4 square panels. How can I show this in a grid, panel form?
Curtain wall maybe?
WW... he want a "ceiling", to simplify this you need to use an "Image", one with the right texture and other (black and white) like an "Alpha channel" to use in the "bump" parameter... With this you can create a "Material" and use it in your ceiling....
Ooops... Did not see that. Make a new lay-in ceiling that has your material assigned to it. You can find perferated metals in your materials.
I tried that but it will not show the perforations in the render (It looks correct in the material preview), it just looks smooth. I just went ahead and created a custom mass panel with perforations and copied it... Slows file down but I couldn't figure out what was going wrong with the other method.
perforated metal or Expanded sheet metal [ 1 2 ] |
Mon, Mar 5, 2018 at 5:55:54 PM
25
Perforated metal panel |
Wed, Oct 30, 2013 at 7:36:33 AM
Perforated metal screen? |
Fri, Nov 12, 2010 at 9:21:25 AM
metal panels |
Mon, Dec 20, 2004 at 6:01:44 PM
Need rendering material for metal roof and metal wall panels. Red paint finish. |
Thu, Oct 26, 2006 at 5:09:26 PM
Members: | 2119122 | Objects: | 23205 | Forum Posts: | 152300 | Job Listings: | 3 |
