70 Users Online (69 Members):
Forums >> Revit Building >> Technical Support >> Reinstalling Revit 2010
24 Posts No Rating |
I've had problems with my PC and several softwares crashed.Among then Revit 2010. After repare Windows (not format C ,I tried to reinstall Revit 2010, but a message says that a newer version was already installed. Then I tried to remove Revit 2010 with window's Add/Remove tool. A message says that patch could notbe opened. Then I tried to remove manually the software manually,deleting all files,folders and registries of Revit 2010, untill it was not listed under programs in Add/Remove list. But when I try to install, the same message displays: there is a newer version of the software installed. But THERE IS NO VERSION installed! What do I do, now? Please,I'm lost! HELP!
It's the first time I heard something like this... "I've had problems with my PC and several softwares crashed.Among then Revit 2010. After repare Windows (not format C " -If I was you I FORMAT the disk.... but i'm not you, so, you must chose..
I really didn't wish to FORMAT it...Now the Windows runs perfect, I've done all updates, service packs etc... All softwares runs perfectly too. Except Revit 2010! I've tried some tutorials to remove it manually, and deleted all references to Revit 2010...But there's still something hidden. The installatiion runs untill the splash window of Revit 2010 appears. Then I click to INSTALL PRODUCT; the next window says there is a newer version installed... There is a registry somewhwere I don't know...
You can try with "REGEDIT" but be careful what you delete...
I've done it three times...All that registries listed by Autodesk ...Hkey etc etc etc.. But still remains something. I guess i'll really have to Format if I want to solve that issue...But thanks a lot.
Trouble Installing RAC 2010 x64 |
Thu, Oct 1, 2009 at 3:47:49 AM
Revit Crashes. Help please. |
Wed, Oct 6, 2010 at 11:02:04 AM
R2010, Vista 64 bit...Crashes!!! |
Tue, May 26, 2009 at 9:46:21 AM
Revit "appcrash" error |
Tue, May 25, 2010 at 2:48:11 PM
Opening a 2010 file in 2009 |
Thu, Jul 16, 2009 at 8:51:56 AM
Members: | 2017179 | Objects: | 22947 | Forum Posts: | 152212 | Job Listings: | 3 |
