59 Users Online (58 Members):
Forums >> Revit Building >> Technical Support >> Visual representation of plan view ranges
Is it possible to show view ranges of plan views like you have for sections. I do not mean just adjusting them in the view properties but visibly showing where the cut line is etc. Thank you, AAron
btw I am using 2010
Your question is not clear. Do you mean the depth clipping properties under view range in VP of a plan?
WWHUB yes I do. When you draw a section or elevation you can visually see in the plan how far / deep the view is. Can you do this with plan views. Maybe in an elevation see the view depth of your plan. I am just having problems setting up my foundation views and wondering if there is an easier way to do it. Thank you AAron
You might try using a 3D view then using the orient to view.
i know what mean. not that i know of. but that would be nice though. you go to section or elevation and turn on plan view range graphics mode for a level and drag and pull to set. nice
View Range visual |
Thu, Dec 16, 2010 at 2:57:32 PM
Visual Style of Beams in Plan View |
Thu, May 22, 2014 at 4:01:03 PM
ovverride graphics |
Wed, May 21, 2008 at 6:10:26 PM
view representation for verticle opening inconsistant |
Tue, Feb 24, 2009 at 7:15:03 AM
plan region view representation re: stairs |
Mon, Mar 2, 2009 at 1:07:14 PM
Members: | 2017191 | Objects: | 22947 | Forum Posts: | 152211 | Job Listings: | 3 |
