41 Users Online (40 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> window does not get cut in plan view.
Thu, Apr 22, 2010 at 4:40:26 PM | window does not get cut in plan view.
Warchitect
4 Stars: 5 Votes
Check out this picture
one window does not get cut by the plan cut plane, even though its set to cut right smack through it. the other window is taller and does get cut, but why doesnt the #13 window. these are family types of the same window by the way, one is 2x2 feet one is 2x3 feet
still it should be getting cut...
also the cut plane thing is so screwy buggy imho.
Thu, Apr 22, 2010 at 4:52:10 PM | window does not get cut in plan view.
GRINHEART
GRINHEART Avatar
4 Stars: 5 Votes
looks like you are cutting thru the frame... try to lower your cut plane a bit more.. maybe 2" and see what happened.
 "If you tell the truth, you don't have to remember anything"
Thu, Apr 22, 2010 at 5:06:24 PM | window does not get cut in plan view.
Warchitect
4 Stars: 5 Votes
Ive moved the cut plane all over the place. up through both windows, right below the head height, etc... so I know they are both being cut, because they are set at the same head height and I can look on the elevation.  yet only one is being cut by the cut plane. Something with the cut plane is screwed. because If i go into the family type and elongate the window, after it gets to about 2'10 tall it suddenly gets cut. But TRUST ME, the cut place has been moved all over to get it to cut the window. the image I posted shows the cut plane set right at 6'5" so both windows are physically being cut...one type is not showing cut though.
Thu, Apr 22, 2010 at 5:13:56 PM | window does not get cut in plan view.
Warchitect
4 Stars: 5 Votes
here is a new picture.
note the windows in elevation and plan, and the cut plane settings...What am I doing wrong? :-)
Thu, Apr 22, 2010 at 5:35:18 PM | window does not get cut in plan view.
Warchitect
4 Stars: 5 Votes
OK I figured it out.
 YOU Must adjust the view range in the library part itself. not just in the project the part was imported into, or it will behave differently from the view range settings in the project. :-)
Tue, Jul 12, 2011 at 10:22:15 AM | window does not get cut in plan view.
zxinfinity
Thank you for this last comment, you helped me figure it out too.
Tue, Jul 12, 2011 at 10:37:21 AM | window does not get cut in plan view.
AbsoluteBIM
AbsoluteBIM Avatar
4 Stars: 4 Votes
thanks for bringing this thread back to the top zxinfinity; i was actually struggling with this today. Great tip.
Window family doesn't cut properly in plan
Wed, Aug 14, 2013 at 6:55:43 AM
Window does not show cut in Plan view of family editor and also in the project.
Fri, Dec 15, 2017 at 1:59:03 PM
Wed, Aug 5, 2015 at 6:44:08 AM
Window fill color in plan view
Tue, Jan 22, 2013 at 4:30:39 PM
Plan Region Oddity?
Thu, Nov 7, 2013 at 9:32:06 AM
Page generation time: 1.1479
