37 Users Online (36 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> gap in wall sweep without wall opening?
Thu, Apr 22, 2010 at 1:38:16 PM | gap in wall sweep without wall opening?
jackjood
Hi!  Does anyone know if it is possble to have a gap in a wall-hosted sweep without having an opening in the wall (i.e. door or window)?  I have a faux-door in a wall, that does not actually cut the wall, so I cannot split the wall sweep (baseboard) to prevent it from running in front of my faux door.
 I could split the wall on either side of the fauz door, but would like to avoid that.
 Splitting a wall sweep like you would a line....  Any thoughts or ideas are greatly appreciated!  Thanks!
Thu, Apr 22, 2010 at 2:57:15 PM | gap in wall sweep without wall opening?
You can grap the grip on the end of the sweep and pull it back to the edge of the opening.  Then place anothersweep in the same place and grab the grip at the other end and pull it to the other side,
Thu, Apr 22, 2010 at 3:14:21 PM | gap in wall sweep without wall opening?
jackjood
Thank you!
Just be sure not to have any overlapping sweeps...
Sweep wrap around external walls with opening
Wed, Jun 25, 2008 at 10:55:56 AM
Wall Openings
Mon, Mar 9, 2009 at 2:40:23 PM
Why does the wall opening cut only go up 2/3 the height of the wall?
Sun, Feb 18, 2007 at 8:53:26 AM
Creating an opening in a swept profile (wall sweeps)
Mon, Dec 9, 2013 at 7:37:14 AM
Wall sweep won't trim
Tue, Apr 25, 2017 at 2:07:18 PM
Page generation time: 3.1130
