76 Users Online (74 Members):
Forums >> Revit Structure >> Technical Support >> View Range help
4 Posts No Rating |
I'm new to Revit Structure 2010 and I'm having trouble getting a foundation plan to display the way I want to. The top of my 16" foundation wall is at the same height as the bottom of my steel columns. I put my cut plane high enough to cut through my steel columns but now I can't see all of my 16" foundation wall. I turned the architect's and my structural floor element off in visibility graphics but the architect's window frame is hiding half of my 16" wall. I tried to turn off only that window element in the revit links visibility graphics box but I can't get only that element to turn off. See attached
17 Posts No Rating |
so, if you have your cut at 5" above, then what do you have for your bottom and view depth?
view range |
Fri, Sep 7, 2007 at 2:28:04 AM
View Range |
Tue, Aug 28, 2007 at 9:52:27 AM
View Range for Revit Link |
Thu, Nov 12, 2015 at 7:10:18 AM
low wall not displaying correctly with view range |
Fri, Aug 3, 2012 at 4:35:37 PM
In place families above the view range are still appearing |
Tue, Dec 23, 2014 at 9:17:05 AM
Members: | 2017179 | Objects: | 22947 | Forum Posts: | 152211 | Job Listings: | 3 |
