Forums >> Revit Building >> Technical Support >> Importing a 3d autoCAD model - preserve individual 3d elements in model
4 Posts No Rating |
Hey all, I've drawn up a 3d model in autoCAD and I want to bring it into Revit to render it. I've brought the model into Revit but Revit essentially makes the whole file one large block. While the layers are still visible, when I click on one, the entire model is highlighted. I've tried going to settings, object sytles, imported objects and assigning materials to my layers there, but when I render, none of the layer take to the material. Please help. I've attached my file. Thanks in advance.
I didn't open your file BUT in the "Materials" check for materials name like "Render ###.###.###", then change those "###" by a material and render, watch what happen... then let me know....
4 Posts No Rating |
Ohh, I see them. I gotta run but i'll try that next. I have a feeling that's going to work. Thanks, I'll let you know.
4 Posts No Rating |
4 Posts No Rating |
Worked! Thanks for your help.
Your Welcome.... BTW, there are lots of thread about this same issue in the forum, try to learn to search here... if you look at the bottom of this page you will see similar threads....
Replacing Structural Elements in Arch Model with Revit Structure elements |
Sun, Dec 4, 2011 at 4:06:35 AM
Importing Autocad background - Revit Model to exceede 2 miles across [ 1 2 ] |
Sat, Apr 17, 2010 at 7:29:53 PM
20
Revit Model Links |
Wed, Jun 23, 2010 at 11:01:01 AM
Archiving |
Fri, Jun 26, 2009 at 11:33:32 AM
Trouble importing AutoCAD survey into an existing buidling model |
Mon, Oct 31, 2005 at 6:24:59 PM
Members: | 2116381 | Objects: | 23194 | Forum Posts: | 152302 | Job Listings: | 3 |
