72 Users Online (70 Members):
Forums >> Revit Structure >> Technical Support >> Leaders
17 Posts No Rating |
In Revit 2010 where is the leader button, also some tags have an arrow head, others dont, how can i change this? Thanks
![stanmpd Avatar](user_avatar/29392.jpg)
![4 Stars: 4 Votes](/images/stars_4.gif) |
Find the tag you want to change in Families under annotations, right click on the tag you want to change and select properties, you have the option to add whatever type of arrowhead you want from the drop down.
stanmpd
Belz A&C
Memphis, TN |
Great thanks, does it apply to text notes too?
For text notes, when you go to Annotate tab on your ribbon and select text, the contextual ribbon for annotations populated with the commands that are specific to text. you will have 4 options for your leaders; No Leader, One Segment, Two Segments and Curved. The actual style of the leader is set up under your text style.
stanmpd
Belz A&C
Memphis, TN |
Leaders moving_Annoying |
Fri, Jan 20, 2012 at 7:37:30 AM
Multiple Keynote Leaders |
Wed, Sep 24, 2008 at 1:27:58 PM
Multiply Leaders with Keynotes! |
Thu, Nov 1, 2007 at 8:25:02 AM
Goofy arcs with dimansion leaders |
Fri, Feb 22, 2008 at 1:44:32 PM
Better Leaders For Dimensioning |
Wed, Nov 24, 2010 at 7:52:57 AM
Members: | 2017161 | Objects: | 22947 | Forum Posts: | 152212 | Job Listings: | 3 |
