Forums >> Revit Building >> Technical Support >> Place Background Image in Render
13 Posts No Rating |
Hi guys, I was wondering how to get a background like this on revit? Im using Revit Architecture 2010, I bet this has been asked a million times, but if someone could put me on to the link to it, or possibly tell me how, that would be lovely! Attached is an image I got out of the gallery not mine, but i must admit a fine piece of work! Thanks
www.goadsby.com Im just a CAD Monkey.... www.twitter.com/GoadsbyCAD |
Render your project, then export the render in a PNG extension, create a drafting view, import that background and then import that PNG file..... and YES there are lots of threads like this in the forum....
Ok thanks. After I have got this in, how do I crop the image to remove the background on nmy rendered image?! I cant seem to find crop!
You don't need to crop anything, when you save the render in a PNG file it's like an Alpha channel... try it...
alpha channel? Sorry for the ignorance, but i have no idea what that means. When i save it has a png file and import it, it still has the background, well the colour around it
no, no, no.... you save the file wrong, after render in the render dialog box you have the "Export" right? click, give it a name and in the file extension choose PNG, i'm sure you save that with other extension...
Applogies i was being a bit stupid! I fixed it, and it works now! Thanks Typhoon
Another you can do it is to make a giant wall behind your model and Decal your desired background onto the wall Helps if you have no access to a graphics software other then paint
- Just trying to help out while I wait in the office for my renders to complete www.danrossiter.co.uk |
can't render background image at 300DPI |
Mon, Oct 11, 2010 at 11:26:57 AM
IMPORT BACKGROUND IMAGE TO RENDER IN RAC2009? |
Tue, May 6, 2008 at 12:25:35 AM
superimposing model on a photo or adding background to a model |
Sat, Nov 29, 2008 at 1:40:23 AM
show background image in render window? |
Fri, Aug 13, 2010 at 2:56:57 PM
Rendering Background |
Sat, Nov 22, 2008 at 5:42:51 AM
Members: | 2098412 | Objects: | 23169 | Forum Posts: | 152292 | Job Listings: | 3 |
