63 Users Online (62 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Dormer Opening?!
Wed, Apr 21, 2010 at 9:33:37 AM | Dormer Opening?!
bengtm
3 Stars: 2 Votes
Now i've been googling, reading the F1, but i haven't been able to do a good dormer opening. Someone who knows and extreme in depth manual for how to do it? It has to cut the roof 90 degrees too, not both cuts straight down.
Cheers
Wed, Apr 21, 2010 at 10:30:39 AM | Dormer Opening?!
GRINHEART
GRINHEART Avatar
4 Stars: 5 Votes
Creater your main roof... create your dormer roof w/ walls and with top/bottom attached to the main roof. now go to the proper view (roof or site view - where you can see the whole main roof/dormer, use this procedure only if you created your dormer roof by using roof by footprint, otherwise go to elevation view if you use roof by extrusion). Now go to Modelling>Opening>Dormer Opening... and just follow the status bar on the lower left corner.
 "If you tell the truth, you don't have to remember anything"
Dormer Opening Not Defined?
Wed, Feb 23, 2011 at 7:53:40 AM
Curved Dormer Roof
Tue, Feb 15, 2011 at 1:31:57 PM
11
Barrel vault dormer opening
Thu, Jun 21, 2007 at 2:22:49 PM
Room bounding in a dormer.
Fri, Nov 8, 2013 at 2:57:00 PM
DORMER OPENING
Thu, Mar 29, 2007 at 1:34:18 PM
Page generation time: 0.2955
