94 Users Online (93 Members):
Forums >> Revit Building >> Technical Support >> Elevator with two entrances?
![3 Stars: 2 Votes](/images/stars_3.gif) |
Hey guys, I wonder if anyone has got a clue about where to find or how to make an elevator with two doors, one at each side of the "shaft"?
If you can't find anything, just apply two components, one at each side of the other....
You can also edit the family and copy/rotate the doors from one side to the other.
Thanks guys, I solved it by using two families that i would turn around and stuff like that ![Smile](/images/smiles/smile.gif)
0 Posts No Rating |
I think elevator complete types set up for the staff, its mostly not a big problem.
![2 Stars: 1 Votes](/images/stars_2.gif) |
Otis elevator has a revit add-in that will create a family for you based on what you input. It's pretty sweet, but kinda technical for use at a schematic stage. Worth checking out though...
http://bimcreate.otis.com/
![Beaucoupnice Avatar](user_avatar/46219.jpg)
![3.5 Stars: 6 Votes](/images/stars_3.5.gif) |
I don't think you can create a family that can cut an opening in two separate walls. But if you REALLY wanted to only use one family, you could edit the lift shaft walls in elevation and cut the required structural openings and then create a lift family sized correctly to suit your lift shaft and show the lift car and lift doors correctly in 3D. The family could be hosted to a floor plane or not hosted at all and simply hover in your model as per the X/Y/Z plane locaiton that you placed it. You would need to either copy the family to each floor level, or you could edit your family and show repeating doors at each correct level.
Here's a snippet of what the Otis add-in can create. I didn't need it here, but i'm pretty sure in the options when you create it you can have doors on opposite/alternate sides. Model comes in pretty detailed, and includes a lot of useful detail for additional space needed for the pit, location of controls, etc...
need help on elevator... |
Fri, May 25, 2018 at 4:23:17 AM
New Elevator Family |
Wed, Sep 13, 2017 at 6:42:18 AM
ELEVATOR |
Tue, Mar 20, 2018 at 6:51:32 AM
elevator BIM model |
Fri, Sep 14, 2012 at 4:04:11 AM
Fire door in front of elevator door |
Thu, Feb 3, 2011 at 1:37:28 PM
Members: | 2017072 | Objects: | 22947 | Forum Posts: | 152211 | Job Listings: | 3 |
