49 Users Online (48 Members):
Forums >> General Discussion >> Revit Project Management >> Joining model-in-place components to create one object
4 Posts No Rating |
I created a custom truss with some 300 members using model-in-place and would like to convert it to a single uneditable object in order to speed up the project file and make the file size easier to handle for the program. Grouping them is not an option as it still saves the individual member info within the group, still big and slow. Any ideas on how to join them? make it a family or mass? Thanks
"In-Place" families increase the file size, is preferable to use a "Family" of an "in-Place"....
4 Posts No Rating |
Thats what my professor told me too, next time that will be the way I go....however that was after the fact and I would still like to use the in-place model I have, any suggestions on that?
Sorry ... next time is maybe this time - you will have to determine. In-place elements should only be created for single use.
36 Posts No Rating |
Since you have already done a bunch of work (albeit down a difficult path), your best option to make your in place modeling into a proper family might be to export to another 3d format (.dwg), and then create a new revit .rfa family. In the new family, you could import your .dwg version of the truss you modeled. You won't be able to put parameters in this family very easily or effectively, but you would at least have your original geometry... I haven't tried this process before, but it seems like it might work. Good luck!
Joining model in place components |
Tue, Dec 4, 2012 at 3:38:20 AM
How to make a "Model in-place" a "Family" |
Thu, Mar 17, 2011 at 5:07:59 PM
Unable to Place Components in Linked files |
Wed, Aug 10, 2011 at 3:11:59 PM
Repeating model in place components |
Thu, Mar 7, 2013 at 1:45:19 PM
Gutter on In-place components |
Thu, Sep 22, 2011 at 10:41:27 AM
Members: | 2066820 | Objects: | 23085 | Forum Posts: | 152272 | Job Listings: | 3 |
