131 Users Online (130 Members):
Forums >> Revit Building >> Technical Support >> rooma area of several room areas
17 Posts No Rating |
REVIT 2010 hi, i have a floor plan where i wwant to show some areas. so i put a room area tag, thats ok and i have four room areas... i need besides to show the m2 of these 4 rooms...how can i do this?} i attached an image of the floor plan...hope i was explicit
You can always use sub-groupings and total those areas. For instance, you could use the department settings for rooms - assign multiple rooms to a department, sort by the departments and areas by departments.
could you help to do that? where can i find this option tu make sub-groupings? or should i make an area plan?
Look in your roop properties, there are already parameters there that you could use... or you could always add a project parameter. You can rfead about parameters and schedules in your HELP
Edited on: Mon, Apr 19, 2010 at 1:47:25 PM
room areas, room separations |
Mon, Jun 2, 2008 at 8:19:42 PM
Room area calculation |
Sun, Nov 25, 2012 at 2:28:44 PM
Room Bounding - Room area changes, then changes back for no reason! |
Wed, Apr 28, 2010 at 6:22:40 PM
Merging Room Areas |
Mon, Jul 27, 2009 at 11:50:56 AM
Calculating floor areas |
Tue, Jul 21, 2009 at 3:42:43 PM
Members: | 2030725 | Objects: | 23003 | Forum Posts: | 152205 | Job Listings: | 3 |
