71 Users Online (70 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Tranfer Families between projects
Fri, Apr 16, 2010 at 11:56:14 AM | Tranfer Families between projects
GNewnum
Is there a way to trafer mulitiple familes that have been updated in one project to overwrite the families in another project?  I.E., We have a template that we begin all projects from.  Several people work on the template and tweak the familes.  Older projects that were started with older versions of the template need to be brought up to speed.  It is a tedious task to open each family in the template, editing the family and reloading them individually (same goes for reloading from the library).  I have tried copying them from the project tree and pasting into the old file in hopes of overwriting but have only succeeded in making additional copies with in the project.
 Please advise.
Thu, Apr 22, 2010 at 9:43:56 AM | Tranfer Families between projects
LIZARD2806
3.5 Stars: 7 Votes
It would be a good idea to have an external copy of the families you have changed.  Assuming there is an external copy already (which there should be if the person editing the family said to save the family after they edited it), you could go into your template, expand the family category in the project browser, then expand each subdivision.  As an example, to overwrite the "Single-Flush" door type, expand FAMILIES, then expand DOORS, then right click on "Single-Flush" and choose reload.  You can then select the family that has been modified.  There may be a better way, but don't know it.
Tue, Mar 15, 2011 at 3:49:17 PM | Tranfer Families between projects
ollienz
ollienz Avatar
Im very late in joining this thread, but I agree there needs to be a way of easily updating mass quanties of families, or alternatively easily updating one family loaded into many files. The latter is a situation we are facing.
Linked Revit files automatically update every time the host project is opened - surely it makes sense to have 'linked' families. An out of date family is no good to anyone.
Tue, Mar 15, 2011 at 4:06:38 PM | Tranfer Families between projects
vector23
vector23 Avatar
2 Stars: 16 Votes
they have been asking this question for years and years about updating
many families at once- but i doubt that will ever happen..
just get a fast processor..
Imperial Projects and Families help needed
Wed, Dec 10, 2014 at 12:53:44 PM
Sharing Families and details between users and projects
Fri, Apr 16, 2010 at 1:48:32 PM
Translating Revit 7 projects (And Office-particular) Library families into Revit
Tue, Jul 19, 2005 at 12:00:01 PM
Views in Families and Projects
Fri, Sep 28, 2012 at 11:12:15 AM
Calculating cost of Nested Families in families in projects - Custom Kitchens
Wed, Nov 13, 2013 at 4:09:29 PM
Page generation time: 0.4485
