Forums >> General Discussion >> Revit Project Management >> Why Can't My Computer Complet A Rendering
I just built a new rig with a water cooling sytem and Quad Core @ 3.6 & 8GBs of ram...... And with all this Horse Power she still can't do a 3.3 mb Rendering in Revit 2010........ I know, check the Task Manager, been there and done that........ Even Max crashes when trying to bring in a Fbx....WOW....... Weird... Can you help me?
If you are on a 32 bit machine, you can only use 4 gig. If on 32 bit, have you set the 3 gig switch? If you are on a 64 bit machine, is your graphics card up to spec?
Yes I'm on a 64 bit machine with Windows 7 Ultimate. Here in my video card spec. ATI Radeon HD 4800 Series Driver Packaging Version_____________________________ 8.702-100202a-0.95693c-ATI Catalyst Version ______________________________ 10.2 2D Driver Version ______________________________ 8.01.01.1004 2D Driver file Path ______________________________ Registry/Machine/System Direct 3D ______________________________ 8.14.10.0738 Open GL Version ______________________________ 6.14.10.0551 Catalyst Control Center Version ______________________ 2010.0202.2335.42270 Memory Size _______________________________ 512 MB. Memory Type _______________________________ GDDR5 Core Clock in MHZ. _______________________________ 750 Mhz. Memory Clock in MHZ._______________________________ 900 Mhz. Total Memory Bandwidth in G Byte/s __________________ 115.2 G Byte/s
Hi Albert, that is a Good machine, very nice horse you have, just a question: do you have already turned ON the Direct3D in Revit?
Edited on: Fri, Apr 16, 2010 at 9:33:34 AM
Here are the requirements for 64 bit system. Microsoft Windows 7 64-bit Enterprise, Ultimate, Professional, or Home Premium editions; Windows Vista 64-bit (SP2 or later) (recommended), including Enterprise, Ultimate, Business, or Home Premium edition; or Windows XP Professional x64 SP2* Windows 7 or Vista processor: Pentium 4, AMD Athlon dual-core, 3.0 GHz or higher with SSE2 technology, or Quad Core Intel® Xeon® W3570 3.20GHz, 8M L3, 6.4GT/s Turbo or equivalent AMD processor (recommended) Windows XP processor: Intel Pentium 4 or AMD Athlon dual core, 1.6 GHz or higher with SSE2 technology 3 GB RAM (8 GB or more recommended) 5 GB free disk space 1,280 x 1,024 video display with true color Display adapter capable of 24-bit color for basic graphics or 256 MB DirectX 9-capable graphics card with Shader Model 3 (recommended) Microsoft Mouse-compliant pointing device Internet Explorer 7.0 or later Download or installation from DVD Internet connection for license registration
Let me check and see if it is turned on....... I'm on my laptop right now. Thinks Ty, and thinks WWHUB........ But Ty, let me check that out.
Ty, can you tell me how to turn on direct 3d?
Under the Revit R pulldown - Options - then the graphics tab.
Your dream computer setup for rendering in Revit? |
Mon, Nov 26, 2007 at 4:35:28 PM
Question on Revit Rendering in Quad Core Computer |
Wed, Jun 10, 2009 at 11:38:39 AM
Rendering Walkthroughs [ 1 2 ] |
Thu, Jul 16, 2009 at 3:03:38 PM
18
Distributed Rendering |
Mon, Aug 17, 2009 at 2:02:39 PM
Rendering Performance [ 1 2 ] |
Wed, Feb 15, 2012 at 6:14:37 AM
16
Members: | 2097649 | Objects: | 23164 | Forum Posts: | 152288 | Job Listings: | 3 |
