Forums >> Revit Building >> Technical Support >> Elements can't be copied because they will lose their References.
126 Posts No Rating |
Hello all Working in Revit 2010. I am building an in place family with various extrusions and sweeps. I have redone and rebuilt it in several different ways and just when I have it built exactly like I want it and hit FINISH MODEL it gives me the "Elements can't be copied because they will lose their References." Error message. I have rebuilt it 3 times making sure to not copy any extrusions or sweeps. I also notice it is highlighting a wall sweep in the model not with in the in place family when it is giving me this error message. What am I doing wrong? I just don't get it. If anyone has any information for me or knows why Revit does this and how I can avoid this please let me know. Thank you, Raina Mc
Hi Raina... well if you attach something in the Create in-place family with "Something" in the Wall, or whatever, you have that kind of error but try this (I don't have Revit Here) create a "Group" with that family and try to copy that Group....
Hello Typhoon. I have an extrusion with a sweep on top and then another sweep on that. Then I have joined geometry on the sweeps and extrusions and all of this is on a wall Is that what you mean by attach? Grouping and copying won't do because each item is similar but not identical. I stopped copying and revising the sweeps and extrusions and just doing each one idividually but still the same error was occuring yesterday. I am currently going back through the in place family and adding one peice and doing it one step at a time to see when the error occurs and today no error so far. I just don't understand where it is going wrong. I am going to keep on building it back to the point I was at yesterday and see if it will work. Is it possible I am trying to put to much stuff in one family. Thank you, Raina Mc
I had the same problem and finaly realised the issue was with using the face of a sweep as the reference plane. You can basically select any other face (or make a new workplane) except a sweep and it'll work fine. Just hit undo until you get back to the sweep profile, and select another surface parallel to the original plane.
Change a copied lever to an original level |
Mon, Apr 19, 2010 at 11:26:42 AM
There is a circular chain of references among the highlighted elements. |
Tue, Aug 30, 2005 at 4:56:02 AM
Monitoring Non-Copied Structural Elements |
Wed, Jun 25, 2014 at 10:27:35 AM
Problem using 'paint tool' within copied groups - Revit 2013 |
Wed, May 22, 2013 at 2:43:15 PM
Beams that are copied are invisible, while beams placed can be seen?? |
Sat, Jan 20, 2007 at 9:53:44 AM
Members: | 2100164 | Objects: | 23171 | Forum Posts: | 152293 | Job Listings: | 3 |
