58 Users Online (57 Members):
Forums >> Revit Building >> Technical Support >> Navis export option from Revit - missing - how do I fix registry to sort?
10 Posts No Rating |
Hi for some reason my export to Navisworks option from the external tools menu on Revit has just disapeared? I think it happened after we had to re-install revit. I worked fine up until this point. We've tired re-installing and reparing Navis in the hope the option with reappear back in Revit. No luck. I think the problem is to do with my system registry. Does anyone know how to manual re-write your system registery to fix the problem? Haven't tired completely removing Revit and Navis and then reinstalling yet - not sure this will fix it as my system reg seems to be abit dodgy. The first reinstall of Revit (when I lost Navis) did not fix the intial problem so we had to ammend the registry accordingly. Using Navis Manage and Revit Structure 2010.
If you havent figured this out yet... all you have to do is repair the navis exporters install from your control panel. make sure that your flavor and year of revit is checked in the dialog when it comes up to list all the different softwares.
http://familyjewels.typepad.com/ |
Navis Export to Revit |
Wed, Mar 21, 2018 at 6:18:07 AM
Navis from Revit 14 |
Mon, Jan 13, 2014 at 10:31:14 AM
export to navis error |
Mon, Jun 17, 2019 at 11:21:02 AM
Export direct to Navis using Shared Coordinates? |
Fri, Dec 11, 2009 at 3:54:25 PM
Revit Export to CAD |
Mon, Jul 21, 2014 at 8:35:51 AM
Members: | 2030530 | Objects: | 23003 | Forum Posts: | 152205 | Job Listings: | 3 |
