47 Users Online (46 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Anotation Key?
Wed, Apr 14, 2010 at 11:31:21 AM | Anotation Key?
Arch145763
I'm making a title sheet for my plans. On it i want to incoperate a key for the symbols I've used in my project so it looks like this (assume typed symbol names are the actual symbol)
(elevation symbol)----- elevation target
(callout symbol)-------- detail callout
ect...   the problem is when i try to incert the symbols on my title page revit will not allow me to do so. I then went and created a new elevation and tried to create the key on the new level to see if i could use the view on my title sheet, but that did not work as it still does not let me use all the symbols.
I also tried to create a new symbol but that also did not work as i could not load all the symbols into it.
It seems as if you can only use certain symbols on certain types of views or something. Is there a way I can make a key for my symbols?
Wed, Apr 14, 2010 at 11:37:14 AM | Anotation Key?
Thread Post Kudo! #2
You have found one of Revit's problems.  You can not create symbol keys.  Instead, Create a legend and draw your symbols there.  You can place legends on multiple sheets and you can transfer between projects.
(If you don't want to draw, you could do a model view where you place all your sysmbols - export to CAD then clean up the CAD and import into your legend view.)
Wed, Apr 14, 2010 at 2:26:01 PM | Anotation Key?
TKennedy
4 Stars: 7 Votes
You don't have to draw your symbols, you can place symbols in a legend.
Wed, Apr 14, 2010 at 2:55:29 PM | Anotation Key?
TKennedy - you are right about detail symbols, but we were talking about callout heads and section heads - tags too.  Perhaps you can enlighten me?
Edited on: Wed, Apr 14, 2010 at 3:06:04 PM
Wed, Apr 14, 2010 at 3:46:09 PM | Anotation Key?
TKennedy
4 Stars: 7 Votes
I just looked, and you can insert section heads etc. in a legend as a symbol. The fields get filled out with the default values.
Edit: I'm using RA2010
Edited on: Wed, Apr 14, 2010 at 3:47:02 PM
Edited on: Wed, Apr 14, 2010 at 3:49:50 PM
Revit Walkthrough; between key frames
Thu, Jul 30, 2015 at 8:22:01 AM
Placing a Key Plan on every sheet (suggestions???)
Wed, Jul 27, 2011 at 8:43:18 PM
Interactive Key Plan
Thu, Jan 12, 2012 at 8:05:16 AM
Key Notes Across Divisions.
Thu, Jan 27, 2011 at 10:07:01 AM
Escape key event handler in revit
Wed, Jul 6, 2011 at 2:44:33 AM
Page generation time: 0.4796
