Forums >> Revit Structure >> Technical Support >> Columns below concrete roof slab lost their hidden lines.
4 Posts No Rating |
Hey all, please help. I can no longer see the concrete columns below my concrete roof slab. I have tried everything I can think of to bring them back, including the hidden line tool, with no success. It's getting really frustrating!
4 Posts No Rating |
Okay, I found I could get them back by unjoining the columns from the roof (10 1/2" concrete floor slab) and then joining them back to the slab, however now the column is cutting the slab, which means columns on the edges of the slab have a line weight significantly lighter than the edge of slab, which looks BAD. Why is this happening?!
4 Posts No Rating |
Is your view range set low enough to pick up the column below the slab?
4 Posts No Rating |
Yes, It's cutting at +1'-0" and the depth is set to -4'-0".
4 Posts No Rating |
hidden columns |
Fri, Mar 26, 2010 at 10:53:36 AM
Show Hidden Lines - Structural Foundations |
Thu, Jan 13, 2011 at 10:37:01 AM
LINESTYLE OF HIDDEN STEEL COLUMNS |
Mon, Jan 17, 2011 at 5:25:38 AM
hidden steel columns showing as solid |
Tue, Nov 23, 2010 at 12:18:43 PM
Attaching columns to roofs? |
Wed, Jan 11, 2006 at 5:59:55 PM
Members: | 2103280 | Objects: | 23177 | Forum Posts: | 152295 | Job Listings: | 3 |
