68 Users Online (67 Members):
Forums >> Revit Building >> Technical Support >> Filter by Phase
9 Posts No Rating |
I'd like to know if there is a way to set up a filter by a particular phase. For example, if we draft Domestic Hot Water piping it shows up red with 2 dashed lines. We have the existing phase graphic override set to a brown color. This works well with setting up a new view with existing work showing. However when we put the Domestic Hot Water filter into the New view it now overrides the phase graphics. One solution we came up with was to create 2 seperate families of pipe types, one new and one existing. However, if there is a way to create a filter that reads the phase it would solve our problem. We could simply put that phase filter at the top of list and no longer have to worry about the new phase filters overriding them. Any input would be greatly appreciated.
9 Posts No Rating |
I still really need a way to do filter by the phase. It would make my life so much easier. We created different line types with filters. However, when I go to demo those pipes the phase graphics are overridden by the filters in the view. Really sucks.
Phase Filter |
Thu, Mar 29, 2012 at 7:54:11 AM
R-17 Wanting to change the phase filter setting in a Walk Through...... |
Tue, Jan 3, 2017 at 11:07:39 AM
Filtering a phase that you have created |
Tue, Dec 5, 2006 at 8:34:41 PM
Walls set as existing not showing up in existing phase settings. |
Sat, Aug 4, 2012 at 11:21:58 AM
New opening cut showing in Existing elevation with [show complete] filter |
Fri, Sep 12, 2014 at 4:21:24 AM
Members: | 2042240 | Objects: | 23026 | Forum Posts: | 152217 | Job Listings: | 3 |
