52 Users Online (51 Members):
Forums >> Community >> Newbies >> rotating reference plan at certain time in model
5 Posts No Rating |
Sorry ignore my other thread, i figured it out up to this point. But one last part is to have the reference plane angle rotate at certain times in the model. This is due to the component as a solar panel, so for example: 35 degrees at 10 am 50 degrees at 1pm... etc. How do i do this?? Thank you so much!!!!
Use "Reference Lines" and create a angular dimension, then convert that dim. to a parameter.... the rest i think you already know....
5 Posts No Rating |
how could you link the parameter to the time of day though? thank you!
I think i'm not understanding the real question here....
This can not be done automatically. You will need to set this as a type parameter in the family that would enable you to change it globally.
Rotate Floor Plan without rotating project |
Mon, Nov 4, 2013 at 1:14:56 PM
Placing 3d Model Text on a Curved Wall |
Sat, Nov 21, 2009 at 5:54:42 AM
Rotating object using reference line |
Wed, Sep 14, 2011 at 4:25:18 AM
Rotating Topo |
Wed, Feb 3, 2010 at 6:45:53 PM
Rotating a Project |
Thu, Jun 29, 2006 at 9:08:00 AM
Members: | 2017260 | Objects: | 22947 | Forum Posts: | 152211 | Job Listings: | 3 |
