81 Users Online (79 Members):
Forums >> Revit Building >> Technical Support >> Calculate Wall Lengths/Area
5 Posts No Rating |
Is there a way to add the lengths of all the walls that bound a room and add them onto a schedule? I need to calculate wall areas but the room is open on one side and a permiter takes into account all four sides, I just want the ones that have a physical wall bounding them. For example, the room is 10' square so it has 30' of walls (with the permiter at 40') I want revit to calcuate the "30'" number in my example. Make sense? Thanks, Mike
Sorry but I don't know a way to do this automatically. Walls will not associate with a room so that is your primary problem. Walls are usually longer than a room - they may traverse several rooms going down a corridor so that is your second problem.
5 Posts No Rating |
Using Area I was able to calculate sq. yards by using a calculated value in my schedule and was really hoping I could "cheat" and let Revit do the wall area for me too. If I have to do that manually, so be it.
![coreed Avatar](user_avatar/14568.jpg)
take a look at this, it may help http://revitrocks.blogspot.com/2010/03/parametric-room-size-label.html hth
How to add wall area in schedule per wall |
Thu, Nov 19, 2009 at 1:10:27 PM
wall area |
Thu, Jun 4, 2015 at 5:00:11 PM
12
How to quickly calculate area like in autocad? |
Fri, Dec 3, 2010 at 10:50:04 AM
Calculate Demolition |
Fri, May 8, 2015 at 3:56:11 PM
Scheduling "System" Curtain Walling Panel Parameters |
Wed, Aug 27, 2014 at 9:24:13 AM
Members: | 2017238 | Objects: | 22947 | Forum Posts: | 152212 | Job Listings: | 3 |
