61 Users Online (60 Members):
Forums >> Revit Building >> Technical Support >> Adding a floor around precast columns
3 Posts No Rating |
Very new to Revit; so this is a basic question. I have the structural framing in place and am adding a floor (it's a garage below grade beneath four floors of condos)
Is there a way to sketch in the floor slab around the column footprints without having to draw around each column? Currently the floor is cutting through each column
I have the column base offset set below the level of the floor slab.
Thanks
![4.5 Stars: 25 Votes](/images/stars_4.5.gif) |
Is Roly not there today?
There are a couple of ways to tackle the problem. The best advice though is to choose the method that is reflective of how the condition actually happens in real life. You could try to "cut" the slab with the column using the cut geometry tool. You could place an opening around one column, group and array it, or you could edit the floor sketch to go around earch column (my last choice if I were doing it).
Call me at JMA if needed (ask Fisher for the number)
Tom Dorner
Post edited on 2005-09-21 15:38:15
![Mr Spot Avatar](user_avatar/1073.jpg)
![4.5 Stars: 93 Votes](/images/stars_4.5.gif) |
I tend to just use join geometry for these conditions.
split precast wall |
Fri, Nov 24, 2017 at 1:17:55 AM
Precast embed connections |
Wed, Jul 30, 2008 at 11:22:13 AM
Showing columns from the floor above |
Mon, Jun 9, 2008 at 1:49:48 PM
Custom Precast Family |
Fri, Mar 18, 2016 at 2:48:12 PM
Joined elements in Reflected Ceiling Plan |
Fri, Nov 11, 2016 at 9:15:47 AM
Members: | 2022277 | Objects: | 22975 | Forum Posts: | 152203 | Job Listings: | 3 |
