60 Users Online (59 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Problem with level display
Tue, Apr 6, 2010 at 11:44:53 AM | Problem with level display
Gitaroo
Hello to you all, this is my first post  here. I am working on a school project with revit and running into some trouble, but I am having problem with the level display. My Level 1 exterior wall is showing on my level 2. But my interior walls show up fine as a grey lines. I and pretty sure that they are both set to the correct height. Any help and suggestion is very much apprecieated.
Tue, Apr 6, 2010 at 12:45:47 PM | Problem with level display
4 Stars: 201 Votes
In that view, check the "View Range"
Tue, Apr 6, 2010 at 12:48:30 PM | Problem with level display
Gitaroo
ya I check already, I dont think the view range is the problem, but I try again by creating a new wall. It shows up as grey line on a differerent level but when I added sweep, it messes up.
Tue, Apr 6, 2010 at 12:52:48 PM | Problem with level display
4 Stars: 201 Votes
Those "gray lines".... Are you working with "Phases"?
Tue, Apr 6, 2010 at 12:58:24 PM | Problem with level display
Gitaroo
nevermind, I got it fugure out, it turns out that my precast for the sweep is 1 mm thicker than the instructor have told us.
Stair Direction Display Problem
Mon, Nov 12, 2012 at 3:47:24 PM
Changing display of walls below current level.
Wed, Jun 18, 2014 at 7:36:35 AM
Accursed plumbing fixture display
Wed, Nov 28, 2007 at 9:29:23 PM
Problem w display of floor patterns over diff. levels
Sat, Mar 19, 2005 at 2:05:24 AM
How to display earth in Floor Level
Wed, Jun 10, 2009 at 6:10:23 AM
Page generation time: 0.8149
