70 Users Online (68 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Systems >> Technical Support >> Low voltage wiring in Revit MEP
Tue, Apr 6, 2010 at 8:45:23 AM | Low voltage wiring in Revit MEP
jcrocco
3 Stars: 1 Votes
Has anyone been able to add low voltage wiring to revit MEP?  Our client would like the low voltage wiring modelled in Revit and scheduled.  If not done in Revit, are there other programs (I.E.: AutoCad MEP) that it can be done in and imported into Revit?
Fri, Apr 23, 2010 at 4:34:27 PM | Low voltage wiring in Revit MEP
Eddieboarder91
Eddieboarder91 Avatar
4 Stars: 8 Votes
I have done it but had to create all the content ot do so...needless to say this took a long time. It would be best if your client is ok with to use ACAD MEP and link like you were saying.
www.allbimallthetime.blogspot.com
http://familyjewels.typepad.com/
actually showing low voltage wiring in the model, is it possible?
Wed, Jul 22, 2009 at 3:16:03 PM
Revit for Low Voltage Structured Cabling
Tue, Jan 13, 2009 at 8:17:18 PM
Labeling wiring runs with panel name
Mon, Jul 14, 2008 at 9:47:53 AM
Electrical wiring
Wed, Nov 12, 2008 at 4:22:37 AM
error: Voltage for the Circuit is out of range for the Line to Ground Voltage...
Sun, Sep 30, 2012 at 12:16:32 PM
Page generation time: 1.7024
