120 Users Online (118 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> footing/foundation/window issue
Tue, Apr 6, 2010 at 8:02:21 AM | footing/foundation/window issue
vblevin
I have a concrete foundation/basemnt wall (with a spread concrete footing) which is furred out on the inside, with windows. The basement slab is on top of the footing, thus the furred inside is the entire lenght of the concrete wall.
Problem- if I model the entire wall as one wall, the footing centers itself on the entire wall instead of just the concrete wall. If I model the wall as two seperate walls then the window doesnt cut through both walls. What is the solution?
Tue, Apr 6, 2010 at 8:33:53 AM | footing/foundation/window issue
You have a couple of solutions.  If you place your concrete wall and add your foundation, then add a furred wall on the inside and join it, that will work.  (join geometry both walls will allow the window to cut both walls.)
Or if your concrete wall is defined as one wall with furring and finish, you can end that at your slab and add a concrete only wall below that.
Edited on: Tue, Apr 6, 2010 at 8:34:53 AM
Tue, Apr 6, 2010 at 9:54:56 AM | footing/foundation/window issue
vblevin
Thanks. It would be most efficient if I could keep the furred concrete wall and just move the footing to the centerline of the concrete  part of the wall.
Tue, Apr 6, 2010 at 4:21:33 PM | footing/foundation/window issue
mbsteve
mbsteve Avatar
4 Stars: 13 Votes
Use the retaining wall footing which can be manipulated from side to side.
lower interior footing to match foundation wall footing
Tue, Mar 5, 2019 at 3:06:53 PM
Strip Footing not wanted in Foundation schedule
Mon, Mar 28, 2016 at 4:05:53 PM
Offset structural bearing foundation footing?
Fri, Jun 19, 2015 at 10:19:41 AM
Foundation Top of Footing (when Level is something other than 0'-0")
Fri, Jan 29, 2016 at 1:40:14 PM
Foundation Plan
Tue, Sep 7, 2010 at 4:47:04 PM
Page generation time: 0.6896
