82 Users Online (80 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Converting a component into a wall?
Tue, Apr 6, 2010 at 12:51:06 AM | Converting a component into a wall?
PatrickReynolds
PatrickReynolds Avatar
Is it possible to convert a component I've created in the form of a wall into an actual wall?  If it's not, then is there a way to create a wall based on the profile of my component?
Tue, Apr 6, 2010 at 7:13:11 AM | Converting a component into a wall?
You can create an in-place element that is an extrusion sweep or revolve that is in the wall category.  You can create a mass and do a wall by face.
Perhaps if you described better what you are trying to do, we could help you more.
Tue, Apr 6, 2010 at 8:39:45 AM | Converting a component into a wall?
PatrickReynolds
What I've already done is create a component for the wall, unfortunately I set it as a furniture component rather than a wall component, so it's not allowing me to add doors or windows are anything like that.  Is there a way to change the component type to be a wall-type?
Tue, Apr 6, 2010 at 9:02:40 AM | Converting a component into a wall?
4 Stars: 203 Votes
Edit that "Wall", go to "Family category and Parameters" and change the category to Wall....
Tue, Apr 6, 2010 at 9:30:33 AM | Converting a component into a wall?
PatrickReynolds
*puts on dunce cap*
I was tying to change its category outside of the edit area, with the element properties...
Thank you very much, that solved that problem.  You wouldn't happen to know what causes this error message while trying to create a mass:
"Unable to create form element: self-intersecting or singular geometry would result."
This is what the profile layout is, each of these is a rectangle, nothing complex.  The only change is in the height.
Edited on: Tue, Apr 6, 2010 at 9:36:58 AM
component with material and recess wall
Thu, Sep 10, 2015 at 7:22:23 AM
ARCH OPENING IN IN PLACE WALL COMPONENT
Thu, Jun 14, 2012 at 2:04:06 PM
converting masses?
Wed, Nov 22, 2006 at 2:48:08 PM
Any known problems converting projects to 2009 form 2008?
Thu, Aug 21, 2008 at 5:49:13 PM
Stair Ends in Landing
Wed, Oct 5, 2016 at 12:52:10 PM
Page generation time: 1.2793
