52 Users Online (51 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Structure in detail level:Course?
Mon, Apr 5, 2010 at 7:16:28 PM | Structure in detail level:Course?
mbkarp
Using Revit Architecture 2010.
I am creating 1/4" building sections and would like to use a course detail level but would also like my structure to not show up as lines.  Is there a way to control this setting?
Medium and Fine basically show the same detail so there is no happy medium for a 1/4" drawing that I would like to see steel sections on.
 Thanks
Mon, Apr 5, 2010 at 7:32:26 PM | Structure in detail level:Course?
itsmyalterego
itsmyalterego Avatar
4 Stars: 16 Votes
The default display settings for beams is only to display in medium and fine, as you know, you can open/edit the family, and check the box so that they dispay in coarse, in full, though this will affect all of your model, if you have other coarse views where you *like* the understated structural look.
Detail level - arch vs structure
Tue, Jan 20, 2009 at 9:05:50 AM
structure model disappear in the detail plan
Tue, Jan 8, 2013 at 1:34:58 PM
Revit Detail Level fill pattern, Texts in Elevation and Section's Symbols
Mon, Jul 30, 2012 at 7:12:54 AM
Sloping 5/14" metal deck roof to sit on sloping OWSJ structure
Wed, Dec 3, 2014 at 8:50:16 AM
Course Detail Level Exposes Wall Ends
Fri, Nov 4, 2011 at 1:16:57 PM
Page generation time: 8.9836
