103 Users Online (102 Members):
Forums >> Revit Building >> Technical Support >> Phasing & graphic overrides
6 Posts No Rating |
I have set my phasing so that new walls are poched dark grey. By default, my storefront glass and mullions also poche. Is there any way to override that? I'd like the mullions and glass without the poche. My intent is to poche the new WALLS only.
72 Posts No Rating |
This all depends by the way you setup your graphic overrides. If you filtered graphic overrides by phasing than you may have to filter the graphic overrides a step further by saying which new phase elements are overriden or not. Try messing with Visibility Graphics - Filters. And see if that helps you find a solution.
Edited on: Wed, Apr 7, 2010 at 2:07:55 PM
----------------------------------- Imagination reveals truths reality obscures. |
6 Posts No Rating |
Thanks Prophecy. I found another work around. I decided not to use the graphic overides in the phase filters because that overides all model elements that are assigned to the new phase. Instead, I made a generic "new" walls and assigned them a poche in the materials setting. That's good enough for now.
The coarse scale fill pattern is useful in general arrangement plans Existing walls with a coarse scale fill pattern and new walls without. Any view set to coarse differentiates new and existing
Graphic overrides (phasing) for 3D views |
Wed, Apr 30, 2014 at 2:25:42 PM
Phase Graphic Overrides |
Wed, Jul 10, 2019 at 4:01:45 PM
Phasing vs materials...Who is the boss when it comes to graphic overrides? |
Mon, Nov 12, 2012 at 9:07:55 AM
Phasing moved to Visibilty/Graphic |
Wed, Nov 18, 2009 at 4:11:56 PM
conflicting graphic overrides... |
Fri, Oct 12, 2012 at 10:44:04 AM
Members: | 2030717 | Objects: | 23003 | Forum Posts: | 152205 | Job Listings: | 3 |
