25 Users Online (24 Members):
Forums >> Revit Building >> Technical Support >> How do I adjust halftone printing
9 Posts No Rating |
Where can I adjust the color of the underlays?. On my printer the default is to light to be usefull. Also, I downloaded some .pat files but they need to be scaled - is there a box somewhere where this can happen.
Thanks
![quiller Avatar](user_avatar/665.jpg)
![2.5 Stars: 3 Votes](/images/stars_2.5.gif) |
I'm not sure on the underlay, except to say that you could use the linework tool and change the color of the wall you need to highlight. You may need to create your own line type and call it wall under or something like that. I do this all the time and it works well.
On the .pat question. If you create a custom fill in Revit, after you browse and get it, as you bring it into Revit at the botton of the window you will see an import scale box. You will have to play around with it for a while in order to get the scale correct. I imported gravel from AutoCAD and it took 3 or 4 tried before I got it right.
Hope this helps........Alan
9 Posts No Rating |
I see the scale box but for some reason the file units and scale factors box is greyed out.
HELP! Printing components in halftone |
Thu, Oct 8, 2009 at 3:53:27 PM
Increase Darkness of Halftone |
Tue, Oct 13, 2009 at 8:08:00 AM
I cannot change the Imported Arch Model halftone. |
Wed, Jul 22, 2009 at 7:15:20 AM
Filters, Fill/Surface Patterns and Halftone or Line Weight? |
Fri, Feb 18, 2011 at 3:11:12 PM
Design Options Halftone? |
Tue, Nov 20, 2018 at 10:58:56 PM
Members: | 2026028 | Objects: | 22991 | Forum Posts: | 152208 | Job Listings: | 3 |
