53 Users Online (52 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> KALWALL
Wed, Mar 31, 2010 at 11:59:45 AM | KALWALL
sagercpl
Using Revit Architecture 2010.
Need to create a roof over an entrance that is KalWall. It's basically 4" rafters with 8" spacing and translucent paneling between them. Can I create a roof system like this without simply using massing?
Wed, Mar 31, 2010 at 12:11:15 PM | KALWALL
Why don't you model the kawall as a roof then the rafters seperately.  8" spacing ... wow, thats really narrow!  I believe you mean 8' ... but that sounds too far.
Edited on: Wed, Mar 31, 2010 at 12:12:41 PM
Wed, Mar 31, 2010 at 12:29:52 PM | KALWALL
sagercpl
no it's 8 inches. theyre not really rafters, structurally speaking, they're more of an aesthetic thing, i just know i can model them as rafters. i've been trying to model them all as a single roof element and i can't figure out if its even possible. thanks for the help tho man
Wed, Mar 31, 2010 at 12:48:32 PM | KALWALL
One in-place family with an arrayed sweep profile should do the trink rather easily.  Just do one path, create the profile and array it at your spacing then you will ahve them all at once.  BTW ... Keep your path on the bottom edge of the rafters - just a hint.
Wed, Mar 31, 2010 at 1:00:50 PM | KALWALL
4 Stars: 203 Votes
Just out of curiosity, what is the shape you want for your Kalwall?? some images will help, if this is what i think, MAYBE with the "Sloped Glazing" system...
KALWALL?
Wed, Nov 15, 2006 at 9:28:50 AM
Editing curtain walls
Wed, Oct 5, 2005 at 10:58:41 AM
sloped glazing
Wed, Jul 14, 2010 at 1:22:41 PM
Curtain wall panel surface pattern
Tue, Nov 19, 2013 at 4:18:44 PM
Page generation time: 0.5104
