23 Posts No Rating |
I use Revit 09 and Structure 09. I do modeling and structure stuff in Structure. The automatic text with the line under it on the drawings is always small. I have tried for hours playing with view properties and element properties to change it to 1/4". I add leaders with various size text with no problem to revit generated detials. I have read many posts and I am still lost. Thanks for anyones help.
Are you talking about a text note in a view, or the view title on a sheet?
![3.5 Stars: 7 Votes](/images/stars_3.5.gif) |
If you are talking about the drawing title on the drawing sheets, you need to update the family. In your Project Browser, expand the Family category, then expand the Annotation Symbols category. Right click on View Title, then click edit on the pop up menu. You will now be editing the family in the family editor. I recommend saving it as a different name when done. After editing, load it back into your family. Next, you'll have to go to a sheet view that has the view title on it. Left click on the title and then click the properties button on the options bar. In the Element Properties dialog box, choose Edit/New. Then under Title, choose the view title you just loaded into the drawing from the drop down list. Let me know if that wasn;t what you were asking. Cheers!
Edited on: Wed, Mar 31, 2010 at 3:43:17 PM
**Using Revit Architecture 2009, 2011, and 2012** |
