71 Users Online (69 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Circular chain of refenrences (Yes, another one...)
Wed, Mar 31, 2010 at 6:45:48 AM | Circular chain of refenrences (Yes, another one...)
marcowip
Hey everyone,
I need help with Revit Architecture 2010. I'm trying to create an dormer opening in my roof by slecting the walls and roof of my dormer. Whatever I try (detaching walls, reset wall profiles, etc.), I keep getting the 'circular chain of references error'.
I have attached broken down file for any of you to look at. It's broken down all the way to just the roof and dormer and the same problem still persists.
I really hope someone can help me, as I've got this problem for approx. 30 instances...
Thanks
Wed, Mar 31, 2010 at 1:20:15 PM | Circular chain of refenrences (Yes, another one...)
4 Stars: 202 Votes
Ok, see this: http://www.megaupload.com/?d=JS4TY47X
Edited on: Fri, Apr 30, 2010 at 6:26:46 AM
Thu, Apr 1, 2010 at 3:00:16 AM | Circular chain of refenrences (Yes, another one...)
marcowip
Typhoon,
 Thanks for your swift reply. That seems to work in the file I posted. I have tried to use the same sequence in my original project file and have been unable to do this. It keeps giving me the same error.
-Reset wall profiles
-Attached base of walls to roof
-Join roofs
-Create dormer opening by selecting exactly the same lines you showed
-Problem persists
Perhaps you have another suggestion?
Thanks
Thu, Apr 1, 2010 at 5:14:33 AM | Circular chain of refenrences (Yes, another one...)
4 Stars: 202 Votes
Yes, first use the "UNJOIN GEOMETRY" and pick in the Dormer roof then do the rest:
-Join roofs
Thu, Apr 1, 2010 at 8:37:42 AM | Circular chain of refenrences (Yes, another one...)
marcowip
Thanks Typhoon!
That did the trick. A million times thanks!!!
Tue, Jun 21, 2011 at 12:35:49 PM | Circular chain of refenrences (Yes, another one...)
sroreilly
Worked for me, too. Thanks.
Wish List - Kill Circular Chain of references
Thu, Apr 10, 2008 at 1:51:30 PM
circular chain refernce
Fri, Jul 21, 2006 at 9:17:19 AM
Circular Chain of Reference
Wed, Apr 23, 2008 at 12:21:54 AM
Circular chain of events
Mon, Sep 11, 2006 at 9:23:06 PM
There is a circular chain of references among the highlighted elements.
Tue, Aug 30, 2005 at 4:56:01 AM
Page generation time: 0.5615
