Forums >> Revit Building >> Tips & Tricks >> roof detail after exterior wall
39 Posts No Rating |
hello i'm kind of stuck here ppl. pls tell me your way of going around things like that. the unsulation of the roof usualy goes only until the exterior wall....after exterior wall it is thinner, because there's no insulation anymore.... how do you do that? do you create to seperate roofs: one until the exterior wall exterior surface, and the second is from exterior surface of exterior wall to the point where it overlaps .... look at the link http://www.paroc.lt/channels/lt/building+insulation/cad+designs/flat+roofs/ssm02.asp of the result that i want to acheave
Not everything has to be modeled. We handel this information in our details. Remember, when using mode sections and details, you can individually modify layers of walls, floors, roofs and ceilings using the edit cut profile tool. That modification is not 3D but is 2D - that view only.
thank you ....i will try just that
I think its a perfect solution for you buddy. I think you must try it. I hope you 'll achieve the results that you want. Good Luck....
i did that and it worked like a charm....thank you
the only problem that it's 2D.....and i cant seem to get feedback of my changes in all other views.....sounds autoCAD'ish to me lol :D
exterior wall update roof problem |
Tue, Sep 23, 2008 at 1:31:28 PM
Repeatig wall sweep vs. repeating detail - wall attached [ 1 2 ] |
Sun, Dec 7, 2008 at 3:51:44 PM
19
Sloped Exterior Wall |
Fri, Jan 15, 2010 at 10:49:41 AM
How do i add wood siding in the exterior wall? Need major help! |
Tue, May 15, 2018 at 9:57:18 AM
Exterior finish on wall not exterior enough... ? |
Fri, Jun 3, 2011 at 8:44:28 PM
Members: | 2115620 | Objects: | 23192 | Forum Posts: | 152303 | Job Listings: | 3 |
