68 Users Online (65 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Dimensioning 3D Views - 2010
Tue, Mar 30, 2010 at 1:19:27 AM | Dimensioning 3D Views - 2010
watta
Hi,
I'm trying to dimension 3D views in 2010.  The dimensions are working although they are not on the desired work plane.  In 2009 there was an option on the menu bar to select the work plane of a 3D dimension - I can't find this in the ribbon or in the new 2010 help menu.
Does anyone know how to change the work plane - or if this can still be done in 2010?
Thanks
Tue, Mar 30, 2010 at 1:35:57 AM | Dimensioning 3D Views - 2010
carlos08
Hi watta,
take a look on revitkid.com. There are a lot of video tutorials, and especially one for dimensioning in 3d.
 Best regards
Volkmar
Tue, Mar 30, 2010 at 1:49:48 AM | Dimensioning 3D Views - 2010
watta
Thanks Volkmar
 I found the tutorial which showed where the set work plane option was.
For anyone reading this post in future - it's under home/work plane in the ribbon menu - it doesn't automatically appear in the dimensions ribbon while dimensioning.
Revit 2010-Dimensioning
Wed, Jan 20, 2010 at 10:47:16 AM
Need help dimensioning this wall!
Sat, Jul 25, 2009 at 10:56:26 PM
Isometric Views and Dimensioning
Mon, Feb 22, 2010 at 3:20:22 PM
Dimensioning railings
Fri, Jul 24, 2009 at 3:04:00 PM
Dimensioning to the centerpoint of an arc
Tue, Jul 29, 2008 at 4:11:55 PM
Page generation time: 0.9752
