Forums >> Revit Building >> Technical Support >> Lintel Schedule
Mon, Mar 29, 2010 at 6:54:27 PM | Lintel Schedule
Beaucoupnice
Beaucoupnice Avatar
3.5 Stars: 6 Votes
Hi,
I need to create a lintel schedule. This will need to include all openings including windows, doors, curtain walling, louvres etc.
Can this be done?
I also need to separate this schedule into separate blocks. I used the department parameter to define these blocks but when I used this parameter within the schedule it did not included openings in the external walls.
Help please
Cheers
Beau
Tue, Mar 30, 2010 at 9:22:06 AM | Lintel Schedule
If you assigned a shared parameter y/n lintel to all objects that have openings and those objects all have a parameter Width (must be same), then you should be able to create a multi category schedule using these fields.
Lintel Symbols NOT to show in Lintel Schedule
Thu, Mar 15, 2012 at 2:40:51 PM
Lintel Shedual
Thu, Sep 30, 2004 at 5:13:41 PM
How to create a lintel
Mon, May 14, 2007 at 4:43:17 PM
Overhead Lintel - Doors and Windows
Wed, Mar 22, 2006 at 4:23:48 PM
want to show Lintel on door
Tue, Dec 2, 2008 at 6:37:55 AM
Page generation time: 0.5479
