22 Users Online (21 Members):
Forums >> Revit Building >> Technical Support >> Surface pattern on stairs
2 Posts No Rating |
Hi I can't get my stairs to show surface patterns in plan view. I have assigned a pattern to the treads (same as connecting floors). Patterns are visible in 3d view, but in plan i only see patterns on connecting floor, not on the stairs. I know that i can override the stair in plan-view with a drafting pattern, but this pattern is not adjustable and the tiles won't fit the steps the way i want to. I can of course also mess it up with detail lines - but that is unacseptabel to me, as there are many stairs, and I dont work in revit that way. Anyone know a solution to this problem?
Hi, see this thread: http://www.revitcity.com/forums.php?action=viewthread&thread_id=12709
2 Posts No Rating |
Hi I had read that post, and from what i understand you found no solution, so i posted the question again in hope that someone had solved it since. As i turnes out: someone has explained the problem. I found the answer in AUGIs forums after i posted here. See this thread: http://forums.augi.com/showthread.php?t=44975&highlight=stair+pattern Regards Armas
Unable to rotate/align surface pattern on stairs |
Thu, Aug 28, 2014 at 7:29:20 AM
Stair Surface Pattern Not Displaying |
Wed, Sep 8, 2010 at 10:05:09 AM
Surface pattern |
Mon, Sep 10, 2007 at 11:18:01 AM
Surface pattern move/align/adjust problems [ 1 2 ] |
Thu, Sep 17, 2020 at 10:29:33 AM
19
SURFACE PATTERN LINE WEIGHT |
Fri, Mar 28, 2014 at 2:30:00 PM
Members: | 2042257 | Objects: | 23026 | Forum Posts: | 152217 | Job Listings: | 3 |
