62 Users Online (61 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Angling Columns
Sun, Mar 28, 2010 at 5:05:06 AM | Angling Columns
skip9
5 Stars: 2 Votes
Is there a way to angle a column, in particular a column that will be used to hold a verandah at the entrance of a building. e.g a column is usually 90 degrees to the ground but is there a way to put it on a angle of 80degrees to make it a feature?
Thanks in advance.
Sun, Mar 28, 2010 at 9:04:49 AM | Angling Columns
3.5 Stars: 395 Votes
You don't say what type of column and that would help.  2011 is supposed to have some better features for this problem.  If you are talking about architectural columns, consider an in place family.
Sun, Mar 28, 2010 at 6:31:27 PM | Angling Columns
skip9
5 Stars: 2 Votes
WWHUB, i am referring to an Architectural Column. I am a newb to Revit so im unsure what you mean by In Place Family
Mon, Mar 29, 2010 at 7:32:19 AM | Angling Columns
An in place family vs a loaded family..  An inplace family is simply created in the project and can not be used in another project.  In-place families are best limited to one of a kind elements and are not meant to be used in multiple locations.
Befire you seven start with this, find the Families Guide on the autodesk site and download that.  It will go through the family building process.
I would model this column in-place using a solid blend.  How to do that will be found in the families guide.
To access the Revit Architecture Families Guide, click (Help) drop-down arrowFamilies Guide.
Welcome aboard.
hidden columns
Fri, Mar 26, 2010 at 10:53:36 AM
Showing columns from the floor above
Mon, Jun 9, 2008 at 1:49:48 PM
Angling an existing hatch pattern
Fri, Mar 5, 2010 at 11:37:31 PM
recalcitrant columns
Tue, Aug 3, 2004 at 7:38:46 PM
Leaning columns
Sat, Jul 2, 2011 at 7:56:56 AM
Page generation time: 1.9657
