104 Users Online (101 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Flat color on curved surface, same color on foreground & background
Tue, Sep 20, 2005 at 4:04:05 PM | Flat color on curved surface, same color on foreground & background
LukeWC
When I assign a color to a wall and view in elevation, the color "bunches" up on the curved surfaces and shows up lighter on walls that are closer to the viewer than the walls that are further away. This is nice for distinguishing these traits, but not good for making a color presentation to a review board interested in looking at the colors. Is there anyway to flatten out this color? Thanks
Tue, Sep 20, 2005 at 5:55:21 PM | RE: Flat color on curved surface, same color on foreground & background
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
Unfortunately no. This is a known issue and wishlist to have flat shaded views without any lighting effects.
Wed, Aug 10, 2011 at 3:36:50 PM | Flat color on curved surface, same color on foreground & background
LRK4Revit
Has this ever been fixed in future versions?  I am having the same issue with round or slanted objects showing gray when they are in different planes.
Wed, Aug 10, 2011 at 7:16:06 PM | Flat color on curved surface, same color on foreground & background
itsmyalterego
itsmyalterego Avatar
4 Stars: 16 Votes
"consistent colors" in graphic display options should do the trick for you.  I believe it was introduced in 2010?
Edited on: Wed, Aug 10, 2011 at 7:16:30 PM
Color Scheme prints as foreground not background
Mon, Jun 6, 2011 at 11:46:18 AM
Room Color Fills from one model to another linked model
Thu, Apr 8, 2010 at 10:40:57 AM
Change Line Color [ 1 2 ]
Fri, May 10, 2013 at 11:03:39 AM
17
PNG- TRANSPARENCY- COLOR SCHEME
Sun, Sep 30, 2018 at 10:09:50 PM
MEDIUM SCALE FILL COLOR AND PATTERN
Tue, Sep 11, 2012 at 7:06:12 AM
Page generation time: 2.5008
