Forums >> Revit Structure >> Technical Support >> hidden columns
On my second floor I have a roof drawn but if I'm looking at the plan in wireframe I can see the columns below. When I change over to hidden (which is what I want to use) the columns go away. The columns are high enough that I should be cutting through them and I see the walls hidden below, so why would I not see the columns hidden below?
Does anybody have a clue on why I'm not seeing the columns?
Something is hiding it ... like a roof maybe?
yeah, I have a roof turned on so that I can see my ridges and valleys. But why would I be able to see the walls below and not the columns below. They are structural columns not architectual.
In VG - set your roof to transparent and see if that gives you what you want.
SWEET! That worked great. I didn't even think about it being in there. That made total sense. Thanks
