51 Users Online (50 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Missing objects in section view (????)
Wed, Mar 24, 2010 at 7:53:18 AM | Missing objects in section view (????)
jawii
Hi!
 I've got a weird situation here.
When i look at my section view, various components are missing; they are still in the model and appear in every other view but the section.
I've looked at vissibility parameters, hidden elements etc., and the really weird part is, that in this case it is a single column that's missing, but all the other columns are visible, also the ones that are placed at exactly the same grid as the missing one (view depth i was thinking)
Now if I tab across the missing column it appears, but I can't get it to show in the view, I've even tried to change the family type and so on, but it doesn't show....
Ive attached a few snapshots that might explain the situation better, I've never had a problem like this before, so hope some of u guys out there might have the cure.
(Tried the old-fashioned delete-and-rebuild too, but still same problem, sometimes with different columns not showing)
 BR/
 JW
Wed, Mar 24, 2010 at 7:56:14 AM | Missing objects in section view (????)
jawii
Forgot to say:
drawing in RAC2010 student version (maybe a general bug with the student version?)
Thu, Mar 25, 2010 at 8:45:54 AM | Missing objects in section view (????)
Kardiff
5 Stars: 3 Votes
Right, i may have an idea but it's only a stab
 That room you are sectioning through K-ST_002.GH
 Your Wall appears to include the column within it's profile
If you added the column element into that wall, it would mean the wall would appear and you would not be able to see the column, but if you added the column inside of it you would be able to pick the element when you try and select it.
I would have your views to 'shading w edges' colour that wall bright red or something and see if it is simply in the way.
Other then that I have no clue sorry
- Just trying to help out while I wait in the office for my renders to complete
www.danrossiter.co.uk
Section View with missing objects at certain height!
Tue, Mar 10, 2009 at 10:41:04 PM
Missing Objects in Section View
Wed, Jan 14, 2009 at 9:28:23 AM
Section tag missing on plan but section still exists
Tue, Nov 22, 2016 at 2:58:15 PM
Section callout missing
Mon, Dec 16, 2013 at 4:00:09 PM
Section callout missing yet Section still Exists
Mon, Feb 20, 2012 at 3:34:46 PM
Page generation time: 1.1881
