Forums >> Revit Systems >> Technical Support >> Where are *blend, sweep...* commands in Massing & Site
Dear friends I have some questions about *Form* function. 1. When I use Masing and Site / In-place mass /Create form, I can't find those five *blend, sweep...*. I can just see these five commands in Home / Build / Compnent.... Isn't it strange? 2. In massing and site, how can I edit any single point of an surface efter clicking *devide surface*? It seems I can just use *Add profile* to edit bigger part of the surface, not only a specific point..... Thank you
1º, see the firs image 2º, see the second image
Dear Typhoon Thank you very much fo your reply. 1. So you mean there is no *blend, sweep....* under *Massing and Site*? What a pity...... 2. For the second question, I didn't mean how to edit those 8 angles' points around the cube. What I would like to know was how to edit any random point on the surface to transform the cube to a *free form* model. Do you know any trick? Than you......:-)
Dear Shenlunglinnk My apologies for being so vague in my previous answer, of course you can use the "Extrusion, blend, revolve, sweep and swept blend", see the video: http://www.megaupload.com/?d=07E5RLSD
Edited on: Wed, Apr 28, 2010 at 6:16:51 AM
Dear Typhoon AMAZIIIIIIIIIIIIIIIIING! Now I get it. Thank you very very much......:-) Have a nice weekend. Best regards Shenlunglinnk
Your Welcome
Sweep and Sweep/Blend Component |
Mon, Apr 23, 2012 at 12:36:52 PM
massing |
Fri, Feb 27, 2009 at 3:52:43 PM
13
'forms' not available in 'in place mass' or components.please help |
Sun, Aug 25, 2013 at 9:11:16 PM
Blend sweep problem |
Tue, Feb 28, 2012 at 1:51:35 PM
Massing Blend |
Tue, Mar 20, 2007 at 11:58:48 AM
Members: | 2115634 | Objects: | 23192 | Forum Posts: | 152303 | Job Listings: | 3 |
