33 Users Online (32 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Interior 3D view
Mon, Mar 22, 2010 at 1:00:26 PM | Interior 3D view
ArchAddict
Sorry if this is an overpost, I tried searching and nothing I thought to search for came up.
Is there a way to move the {3D} view inside a building? or convert a camera to a parallel view. I want to be able to paint walls and modify some objects from the 3D view instead of having to cut sections and take interior elevations of every wall, ceiling, etc. I would like to be able to fly around inside the building and tweak things so make sure they are represented correctly.
Maybe I'm missing some technique completely. Let me know how you guys apply finish materials.
Mon, Mar 22, 2010 at 1:03:31 PM | Interior 3D view
You can not modify objects from a tue 3D view.
You can place a camera anywhere.
Try using scope boxes and axionmetric 3D views.
Tue, Mar 23, 2010 at 4:53:27 AM | Interior 3D view
Kardiff
5 Stars: 3 Votes
Duplicate your 3D and go to the view properties and click on 'section box'
using the section box you can isolate the room you want and spin it, paint it etc
or go into 3D highlight the elements you want and press isolate elements
- Just trying to help out while I wait in the office for my renders to complete
www.danrossiter.co.uk
Render exterior view with artificial lights - how to make interior glow?
Sun, Mar 11, 2012 at 12:45:29 PM
INTERIOR ELEVATIONS - ADVANCED MODEL GRAPHICS
Mon, May 4, 2009 at 8:45:29 AM
split segment on interior elevation view callout?
Tue, Sep 13, 2011 at 3:32:41 PM
Axonometring Section of interior - with whole furnitures.
Fri, Aug 6, 2010 at 8:23:25 AM
Can I set default interior elevation view extents?
Thu, May 29, 2014 at 8:10:09 AM
Page generation time: 1.5557
