29 Users Online (28 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Systems >> Technical Support >> Corrupt Families! Corrupt Model groups! Yikes! Any tricks?
Fri, Mar 19, 2010 at 10:14:28 AM | Corrupt Families! Corrupt Model groups! Yikes! Any tricks?
KKERRIDGE
KKERRIDGE Avatar
2.5 Stars: 3 Votes
We have been having some difficulties with an Architectural model for linking into our MEP model. Originally, we were unable to purge unused elements due to a handful of model groups apparently being corrupt. Every time we went to purge we would get an error message that: This action has caused the deletion of non-editable workset XXX”
I was able to over come this by running in a debug mode called “allowdeletionofnonemptyworksets” ungrouping all the other model groups, and putting the corrupt ones on a separate workset, then closing that workset through the entire project, opening up a floor plan and making its view range unlimited both directions and saving that floor plan (which now enveloped the entire building via view range) to a new file.
Once that was complete I moved all the room separation lines out of walls, and resolved a few unjoined element errors. (possibly related to ungrouping?)
After I resolved those errors, removed materials and purged unused. I saved the file, audited and compacted it. It still ran slow when inserted into our MEP model.
heres where the new problem lies:
I then went back into the file, and went to investigate the families. When I open the families, I either received a “serious error warning”: (see attached)
Which closes the family.
OR the family will open, and most of the building envelope is contained within the family.
any Ideas???
Tue, Feb 28, 2017 at 5:57:38 AM | Corrupt Families! Corrupt Model groups! Yikes! Any tricks?
amitshah316
What are you current Revit Updates and are all users on the same updates.
what is your machine spec
Tue, Feb 28, 2017 at 9:23:27 AM | Corrupt Families! Corrupt Model groups! Yikes! Any tricks?
3.5 Stars: 401 Votes
Why are you editing the linked file are you going to do that with every update?  There is no need to do this if you are only linking since only the model elements are loaded and only loaded each time the file is used, nothing is added to your file so no space is taken.
Corrupt Dwg? - Can't load families [ 1 2 ]
Thu, Jul 16, 2015 at 10:55:31 AM
17
Corrupt Elements Are killing US
Wed, Aug 22, 2007 at 12:35:38 PM
Corrupt Files
Tue, Mar 15, 2016 at 3:33:10 PM
Elements Corrupt
Mon, Dec 3, 2012 at 7:42:26 AM
Manually Recovering Corrupt Files
Tue, Jun 28, 2016 at 6:55:36 AM
Page generation time: 0.8326
