Forums >> Revit Building >> Technical Support >> Instance Shared Parameter??
12 Posts No Rating |
I am trying to add a shared parameter to our 8.5 x 11 titleblock for ASI's and want a label that can be edited as an instance for the referenced sheet number. I made a shared parameter for this since it wasnt in the list of available ones, but how do I make it editable per instance? Right now i just get the ? in the field when the title block is inserted into the project. Any help would be appreciated!
16 Posts No Rating |
i think you need to load the shared parameter into the project (in addition to the sheet family) (maybe)
Edited on: Tue, Jul 13, 2010 at 9:25:26 AM
72 Posts No Rating |
i have this same problem, and I need it editable per instance.
I got it to work but once I change it on one sheet it updates every where on all the sheets... what do I need to change??
Edited on: Thu, Jul 10, 2014 at 7:50:39 AM
----------------------------------- Imagination reveals truths reality obscures. |
Add that shared parameter to your project and template and set it there when you add it as an instance parameter.
could you please explain this a little more?
"set it there when you add it as an instance parameter"
? Thanks bud
Shared Parameter Over Constrained Planes |
Thu, May 18, 2017 at 2:13:22 PM
Titleblock Parameter is now Instance instead of Type |
Tue, Feb 17, 2015 at 3:31:01 PM
Instance Parameter to control another Instance Parameter |
Thu, Jul 22, 2010 at 6:22:49 AM
Cannot Locate SHARED PARAMETER FILE! |
Tue, Oct 7, 2008 at 3:16:49 PM
Egress Door Tag |
Tue, Mar 12, 2013 at 3:29:33 PM
Members: | 2098924 | Objects: | 23170 | Forum Posts: | 152292 | Job Listings: | 3 |
